Hey peeps,
I've recently built my new system and finally got it all working smoothly, so thought it was time to tinker with it and up the clocks a bit.
I've got a 2900GT, the card itself comes with an 8 pin power socket, however they only supply you with and 6 pin adaptor - it states that you have to have the 8 pin to be able to overclock it in the ATI tools, can i get around this??
I've tried using rivatuner 2.06, but there are no hardware options available at all...
Also when looking at the card on GPU-Z it's reporting only 509mhz on the gpu, and 510(1020)mhz on the memory, when it should be 600/1600 which has got me worried. On the flipside to that however, i think it's only supposed to have 240 shaders, but it's reporting 320? It's running 41/48 degrees at idle.
Has any1 got any ideas on how to sort this and get some clocks up?
Cheers in advance!
Cheers in advance!
