Hello,
18 months ago I brought a pre overclocked system here and until recently it’s been running perfectly, however now it won’t boot with the overclock.
Symptoms:
Turning the system on I received the following error message:
The system had experienced boot failures because of overclocking or changes of voltage.
Last settings in BIOS setup may not coincide with current H/W states
Current CPU Speed: 2.80GHz
Current BCLK: 133Mhz
Current Memory Speed: 1066MHz
Going back into bios saving and exiting causes the system to not boot requring a reset, and then display the message on the following boot.
If I just boot after the error message the system functions normally EXCEPT RAM is only displayed as 4GB on the POST screen and in windows 6GB installed with 4GB available.
Apart from turning off hyper threading and adding an extra hard drive and a second SDD the system is exactly how I brought it. I havent touched the overclocking settings, the normally overclock is 4GHz.
Any help appreciated.
System specs below:
"Ultima Viper" Intel Core i7 930 2.80GHz @ 4.00GHz DDR3 System
SW-129-MS Windows 7 Professional 64 bit OEM
MB-235-GI Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3
Motherboard
CD-099-LG OcUK 22x DVD±RW SATA ReWriter (Black) - OEM
HS-005-PL Prolimatech Megahalems Rev B CPU Cooler (Socket
775/1156/1366)
CP-318-IN Intel Core i7 930 2.80GHz (Bloomfield) (Socket LGA1366) - OEM
HD-211-SE Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache - OEM
(ST31000528AS)
FG-006-SH Sharkoon Silent Eagle 2000 120mm Fan - 3/4 Pin
MY-008-PA Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Low
Latency Tri-Channel (PVT36G1600LLK)
CA-110-AN Antec 902 Nine Hundred Two Ultimate Gaming Case - Black
GX-134-OK OcUK Value GeForce GTX 480 1536MB GDDR5 PCI-Express
Graphics Card
CA-023-CS Corsair TX 950W ATX SLI Compliant Power Supply
(CMPSU-950TXUK)
HD-050-OC OCZ Vertex 96GB 2.5" SATA-II Solid State Hard Drive
(OCZSSD2-1VTX96G)
Symptoms:
System specs below:
Motherboard
775/1156/1366)
(ST31000528AS)
Graphics Card
(CMPSU-950TXUK)
(OCZSSD2-1VTX96G)
