I got a new PCI-e mobo Gigabyte Ga-K8ne2for my old s754 a64 3400+. I put in an x1900xt which is really nice, cause its super fast and I can port it over to my upgrade after xmas
I'm more than happy with the gfx card, its awesome, and a great little overall upgrade to keep me going a few months.
There is one problem though - I cannot do any overclocking whatsoever. I've done this many times before, I know what i'm doing - I've dropped the HT Bus to 3x, used a memory divider and slackened the timings, set the PCI-e speed at 100mhz.
But if i even change the bus speed to 205, than prime 95 fails almost instantly. You can also see some mild visual artifacts in doom3.
The vcore voltage looks a little shaky in CPU-z and Speenfan, bouncing between 1.45 - 1.49. My CPU requires 1.5, but I've always assumed thats a max value. I've no other way to test the voltage.
I'm wondering if the PSU is stretched. I'm using an old Tagen 480 with a converter to plug 2 molexs into a 6 pin PIC-e power adapter. The x1900xt is probably sucking the life out of this thing :-/
Is it possible its the PSU? Anyone had any positive experiances from changing the PSU? I have to get a new one next year anyway. I can do it now if it adds value to this system.
Edit - I used to get 2.4ghz out of that CPU on my old mobo easily.
I'm more than happy with the gfx card, its awesome, and a great little overall upgrade to keep me going a few months.There is one problem though - I cannot do any overclocking whatsoever. I've done this many times before, I know what i'm doing - I've dropped the HT Bus to 3x, used a memory divider and slackened the timings, set the PCI-e speed at 100mhz.
