Overclocking done.
18 Oct 2009
Just finished my latest build:
Ryzen 7 2700x
Asus crosshair hero 7 x470
16gb G skill trident z C14 3200
Msi rtx 2080 duke
Superflower gold 750 psu
Fractal define R6 case
Phanteks ph tc14pe with 2x rajintek rgb 140 fans
6x corsair ml140 fans
I have managed to achieve the following results which im pretty happy with
Graphics - +1300 mem clock, +140 core clock, no voltage change
Cpu - 4.250 ghz all cores at stock 1.35v
Memory - 3466mhz clock at 14-14-14-28-1t at 1.38v
Pretty chuffed with the results!
Did you give XFR a go instead of the manual all core OC?
I got surprisingly better results in everything except Cinebench using XFR instead. Just a thought. :)
Couldn't get my RAM stable at CL14 at anything much over 3300Mhz unfortunately.
XFR is the future, it dose a VERY good job. you should do some AFR testing first just to give yourself a base line, your OC could be worse then just letting the CPU is it.
4.25Ghz with the memory speed and timing is nice
