You have speedstep enabled which lowers the multiplier when idle and raises when stressed.
What cooler are you using, and double check temps with core temp and Real Temp.
When i take the speed step off my temp are 57 on no load![]()
You need to invest in a half decent cooler. The stock cooler is not really desinged to cope with overclocking. Arctic Cooling Freezer 7 Pro is a good budget choice or an Extreme if you want to splash the cash.
Wow. Just got a 7 pro and now my temps are down to 35C!
Thanks for the help.
That was quick going.![]()
Did that and lost another 5C (Got it down to 1.2v so far). Thanks!
