Overclocking E6600
17 Apr 2007
stat city
If you read my previous thread, you'll see the problems I've ran into. here
I've never overclocked or even changed the bios. So, I'm a complete beginner at this. I'd like to overlocked my cpu to the fastest speeds my pc can handle.
My pc came overclocked but then I had to get the motherboard replaced and I guess my cpu went back to stock speeds.
system specs:
Intel Core 2 DUO E6600 2.40GHz Dual Core CPU Overclocked too a minimum of 2.93GHz and beyond. (9 x 333MHz - 1333MHz FSB)
- Arctic Cooling Freezer 7 Pro Intel approved cooler
- Arctic Silver 5 Heatsink compound professionally hand installed by our technicians
- asus P5N32-E SLI PLUS motherboard
- Award winning G.Skill PK 2GB Ultra PC2-6400 CAS4 (2x1GB) Dual Channel Kit (Overclocked at 900MHz+)
- 500GB Western Digital Enterprise 16MB Cache SATA-2 Hard Drive
- NVIDIA 8800 GTS 640MB GDDR3 VIVO HDTV/Dual DVI (PCI-Express) DirectX 10 Graphics Card
- NEC 7173 18x DVD±RW Dual Layer LabelFlash ReWriter (Black)
- Black Sony Floppy Drive
- Antec NINE HUNDRED Gamers ATX Case
- BFG 800W Next Generation Power Supply
Any help overclocking this would be very much appreciated.
Could a mod move this to the overclocking forum? Thanks.
some settings.
Thanks. I read those threads and I think I overclocked everything correctly. Shouldn't my DRAM be higher than 333.3 though?
You have DDR2 6400 so it should say 400mhz in CPU-Z. You're running 1:1 though which isnt bad. at 400mhz and 333fsb you could have a 5:6 ratio if I remember correctly.
keep riseing the fsb
my E6600 gets too 3.24 (360*9) at 1.35v.
you could also try droping the multi to 8x and (400*8) will give you 3.2 but the extra fsb will give a greater preformance boost that the above
9x clock.
Personally I alway keep the ram divider at 1:1 if your ram will clock to 900 you may acheive the 3.6 sweet spot (with .1v extra volts and maybe a little extra on the chipset too)
Edit: but I thing the sli boards don't acheive such high fsb as the intel and/or Xfire boards with this chip
totally got nothing to do with your topic sorry but heres just a screenshot of me overclocking my e6600, might help in some way maybe? by scanning it and the data on it.
voltage in bios is 1.675v but it drops a hell of a lot because of my duff motherboard lol, but it runs stable and has done for the past 3 months so should be stable to run for a while yet. had the cpu at over 3.6ghz now for 20 months at over 1.55v.
Don't think it would be safe for me to set the FSB to 4250.
What would I set the FSB to for 3.2mhz?
for 3.2ghz you would need 355 fsb, and voltage wise you would need to raise the vcore voltage a tad for stability unless you have a really good clocking chip, mine only does 3.1ghz without voltage raises
So I just change the FSB QDR from 1333 to 1335?
What clock speed do you think would be best?
It depends what you want to do with it, as to what clock speed would be best for you.
For general use, 3Ghz would be enough. For gaming, 3.2-3.4 would be best. Anything higher is for epeen benchmarks or an extra 2fps in Crysis (my reason :D)
