Ok, Just put a new system together and want to try overclocking the CPU, i have read number of threads about my p35 board and also the noob guide at the top of this thread.
I had a quick look at the Bios and as far as i can see i need to disable the following:
1 - C1E,
2 - TM2
3 - CPU Eist ( couldnt see it )
Other options need to be set to manual to be able to adjust the FSB ( again couldnt see this ) unless its the CPU host clock control ?, if someone could explain would be great, also do i need to set the ram multiplier to 2.0 or cant that wait? also should i adjust the voltage on the ram by 0.3 to make it run at 2.1 ?
Now what i want if some one could just tell me what numbers to set where would be great.
1 - C1E,
2 - TM2
