Definitely from within the BIOS...![]()
Ok, so its not good to use something like easytune5 to do it? Does this damage the chip in some way? Or is it more stable via BIOS? I'm using the Gigabyte P31-DS3L.
You might need to add more vcore??
Naud
Not sure on the voltage readings, but I've got an E8200 and 4GD gold OCZ which I assume is pretty similar.
Got mine on 425X8 - 3.4Ghz. Only upped the voltage to 2.0v. No other changes.
Clock well![]()
