Hi there!, I'm quite new at the overclocking stuff but I have been reading a couple of thread for a while now but I could not keep myself to ask a few questions to people who know more of this than I do.
For starters, here is my setup (dates back to August '08)
Antec Sonata 3 + 500Watt
NEC AD-7203S-0B SATA Labelflash Black
Intel Core 2 Duo E8400 (3GHz, 6MB Cache, Box)
Asus P5Q Pro
Samsung 320GB SATAII
Sapphire Radeon HD4850 (512MB DDR3 - clock 625Mhz - Fan)
Arctic Fan 120mm (AF1025L)
Corsair 4096MB DDRII 800Mhz (4-4-4-12)
Scores on 3DMark05: 3DMark Score 17226 3DMarks | 13968 CPUMarks
The temperatures:
E8400 idle: core#1 39-42°C
core#2 39-42°C
HD4850 idle: 72-74°C
Regarding those temps, I suspect that the ones received from the CPU are quite normal? (Everything is standard fans just 1 eextra 120mm fan to improve airflow) While the temperature of the graphicscard is, atleast to my opinion after reading some threads, quite high? the fans are at 25-30%.
Now, when I'm powering the fans up to 100% (something I have to do when I'm going to play a game or something heavy for my graphicscard, cause else my screen falls out and I guess it's my graphicscard which shuts down when it gets too hot). So when powering up to 100% (the fans) I get following results:
those of the e8400 are sorta the same (stable at 40°C - both cores)
those of the HD4850 idle: 54-58 °C
a big difference then before, but how is this possible? The card has not been overclocked or anything and I even put in an extra fan (120mm) to improve airflow.
Also, do you guys recommend starting to overclock, when I'm inexperienced so far and I'm not going to invest into watercooling and stuff like that, when looking at the high temperatures I'm already getting now before overclocking. Or should I just invest in a year or so and buy a new CPU and a new Graphicscard?
And last, if overclocking is the answer, what should be the first thing to check/buy to get started? Better fans, after market coolers, upgrade bios, what tools to get,...?
I thank you all already !
Asus P5Q Pro
The temperatures:
core#2 39-42°C
I guess you still have the stock cooler on your cpu then. Definately upgrade before giving that E8400 what it was made for. i.e. A nice big phat overclock.
