Hi,
was running my E8500 C0 at 4ghz, for couple months, just today noticed in BIOS (asus p5q-e motherboard) following:
CPU GTL VOLTAGE REFERENCE (1/3)
min. 0410x
max. 0.800x
STANDARD: 0.670x
CPU GTL VOLTAGE REFERENCE (o/2)
min. 0.370x
max. 0.760x
STANDARD 0.630x
NB GTL REFERENCE
min. 0.370x
max. 0.760x
STANDARD 0.630x
at 4ghz, I was setting ALL GTL's to 0.66x
but as you see, (1/3) GTL's standard setting is 0.670x
so definitely it did not run on right setting!?!?!?!
I should increase above standard as O/Ck'ng?
can someone tell what numbers should I set to all GTL's?
min. 0410x
max. 0.800x
STANDARD: 0.670x
min. 0.370x
max. 0.760x
STANDARD 0.630x
NB GTL REFERENCE
min. 0.370x
max. 0.760x
STANDARD 0.630x
