overclocking E8500 - making a start
20 Oct 2002
Space, the final frontier
I've never really had a go at overclocking before and dont plan to kill my PC, however having read plenty of threads with people squeezing some extra performance out of their kit, I fancy a go
This is what I have
E8500 E0 cooled with a Noctua U12P (Akasa 120mm Fan)
P5Q Deluxe - 2001 Bios
4x2GB Hyper-X PC8500 (currently running at PC6400 1.8v)
2x 250GB Samsung Spinpoint Raid 0
HD4870 1GB
HX620
Vista X64
running as it is, using Orthos, both cores hit 40c at full load
Does anyone have this mobo with 8GB and could suggest some settings to try, even if its just to get the memory running at its rated speed?
Thanks
Try these. Should be stable.
and what is the VID on the chip? CoreTemp will tell you this.
JumperFree Configuration Settings
AI Overclock tuner: Manual
CPU Ratio Setting: 9
FSB Strap to North Bridge: 333
FSB Frequency: 450
PCI-E Frequency: 105
DRAM Frequency: DDR2-900MHz
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 5
RAS# to RAS# Delay : 15
Row Refresh Cycle Time: AUTO
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Static Read Control: DISABLED
DRAM Read Training: DISABLED
MEM. OC Charger: ENABLED
AI Clock Twister: LIGHTER
AI Transaction Booster: ENABLED
Performance Level: 9
CPU Voltage: 1.3
CPU GTL Voltage Reference (0/2): 0.655
CPU GTL Voltage Reference (1/3): 0.655
CPU PLL Voltage: 1.52
FSB Termination Voltage: 1.20
DRAM Voltage: 2.02
NB Voltage: 1.28
NB GTL Reference: .63
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: DISABLED
CPU Spread Spectrum: DISABLED
PCIE Spread Spectrum: DISABLED
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
CPU Margin: PERFORMANCE
Advance CPU Settings
C1E Suppport: DISABLED
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Enabled
Execute Disable Bit: Enabled
Hi Gurusan, thanks for the starter, i will try those settings shortly, the vid shown in coretemp is 1.1750v, dont know if thats good or bad?
That's a very good VID. I had a 1.175VID chip and it did 4.7ghz game stable at 1.408V and 4.5GHz prime stable at 1.37V
hi Gurusan, I tried those settings, but the system didnt post
i couldnt set this to DRAM Frequency: DDR2-900MHz, but it was 901MHz
What do I need to reduce in order to get a result?
Thanks
Sorry, try Performance Level should have been 10. Usually when running 1:1 fsb/dram ratio you need this to be at 10.
901mhz is fine
hi Gurusan, still doesnt want to post, do you think it's due to having 8GB?
Are we at a lost cause and should just keep it at stock?
Thanks
It's got to be the 8GB. It's not a lost cause though.
Try keeping all the settings the same, but change the multiplier to 9.5X and set the FSB to 422
ok it now posts, but doesnt boot
has the error "not enough space to copy PCI option ROM [00:1F:02]
Also the dram speed has dropped down to 845mhz
Can I chip in with an E8500 overclocking story? I had my E8500 prime stable at 4.5GHz 500x9, both in the cpu only stress test and the cpu+memory test, this was with 1.4V. However, Crysis was the only thing to crash on me. It would freeze, but it wasn't a total pc lock up, I could crtl-alt-del and end the task. I don't think it was the gpu clock as I tried lowering this back to stock and it still did it. I had to drop to 4.05GHz to play the game without any lock ups, but as I say it was fully prime stable at 4.5GHz otherwise. ANy ideas or would this just be another Crysis perculiarality?
Here are my current settings with a Q9650, vid=1.25, BIOS 2001, for 4GHz Prime & IntelBurn stable:
JumperFree Configuration Settings:
FSB Frequency: 445
PCI-E Frequency: 100
FSB Strap to North Bridge: AUTO
DRAM Frequency: DDR2-1069Hz
DRAM Timing Control: AUTO
DRAM Static Read Control: AUTO
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
CPU Voltage: 1.29375
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: 1.54
DRAM Voltage: 2.12
NB Voltage: 1.20
NB GTL Reference: AUTO
SBridge Voltage: 1.10
Load Line Calibration: ENABLED
CPU Margin: OPTIMISED
Advanced CPU Settings:
Max CPUID Value Limit: DISABLED
Intel® Virtualization Tech: DISABLED
CPU TM Function: DISABLED
Execute Disable Bit: ENABLED
I had an E8400, C1 stepping, vid=1.18, in this before the Quad. I had it at 3.6GHz, 400 x 9, 1066 RAM, 1.2v CPU. All other settings the same.
I think you are trying to run before you can walk. Try for 3.8GHz (400 x 9.5) at say 1.25v CPU. If that's stable reduce CPU volts a few steps at a time to find the lowest stable.
You may need to up the NB volts for the Kingston RAM, My reaper is fine at 1.2V.
ok, ive set it to what barkeep suggests and its running at 400x9.5 - 1.2v in the bios, cpu-z showing 1.192v at load using prime95
Now, how do I get the ram to run at PC8500 speeds or am i just going to have to leave it a pc6400?
I left prime running for one hour and the load temp (using coretemp) was 48c on both cores
