I can't remember exactly when but I said I had this processoer up to 3.8GHz when coppmparing it to my AMD 955 at the same speed.
Since then I Overclocked it to 4.0GHz a few nights ago and this morning I got it to 4.4GHz (464 x 9.5) @ 1.4v.
Temps after 5 hours shows as follows
core #0 = Low 30 - High 53 - Idle 32
core #1 = Low 30 - High 51 - Idle 32
Correct me if I'm wrong but isn't the official limit for voltage described as 1.3625v?
During a stability check it crashed during 1.3750v so I pushed it to 1.4. I've seen others use at most 1.6 so it would be great if I still have 0.2v to play with.
Can I go any further with this processor or have I maxed out again?
Other components are
MB - Asus Formula Rampage
Ram - 4x 2GB OCZ 800MHz Gold
Current cooler - Zalman 9900
If there's more potential I'll watercool it but I always reach the max voltage before I need it
