Overclocking, finishing touches = Help needed :)
Permabanned
28 Feb 2006
Hi,
Well I have the Amd 64 3000 Stock speed - 1.8ghz
Im at 2.5ghz, now. The divider is at 166, on my Crucial value ram.
Ram is at 225mhz...
Erm, timings are poor though, I have loosened them :
3-4-4-10
So, what should I do to help this?
Which ram timing shall I TIGHTEN?
Thanks everyone! In advance! :)
what exact type of crucial ram is it? 1gb of what?
if its value/standard stuff then try 3-3-3-8
Crucial 2x512mb PC32000
Just gone 3-3-3-8
Super pi 1m finished in the exact same time 36 seconds.. :confused:
Erm, will check stability in prme first.
