- 1 Mar 2008
- Near Longleat, Raaaar!!
Hi Guys,
Just invested in a nice shiney new q6600 from overclockers as my poor old Pentium d915 was struggling with Crysis. It's made a huge difference at stock speeds, not only for the games but load up times too but I couldn't resist having a go at overclocking it. Although I've read as much as I can find on forums and guides about overclocking i'm a bit new at this and having a few problems.
It will happily run stable at 2.9ghz without having to change any voltages but at 3.0ghz (1333FSB) it loads vista fine but then reboots. No BSOD but wont last for more than a minute in Vista.
I've tried various combo of raising the vCore, CPU Vtt & NB voltage to no avail, and even bought a new PSU as I thought it might be the 450W PSU that came with the case that was the problem, but it still does exactly the same.
Strangely, If I do start raising the voltages more than 0.05v (CPU Vtt & NB) It sometimes wont even boot at all. I don't think its temperature as CPU temp doesn't go above 45c for the whole minute it actually runs.
I've trawled the forums and most people suggest that the G0 stepping of the q6600 should do 3ghz on stock voltages and if it doesn't its probably just luck of the draw with the CPU I got. Thats fine if its the case but if anyone has any ideas they would be most appreciated.
If you want any other info just ask and I'll try to find it for you. Thanks In advance
