I fancy overclocking my new build but I'm a noobie at OC so I need some help,
I currentlu have:
GA-EP45-DS3R
Intel Core 2 Duo E8500
(2x2GB) Corsair TwinX XMS2, DDR2 PC2-6400 (800), Non-ECC Unbuffered, CAS 5-5-5-18
Graphics: 512, 4850 ATI.
When OCing the graphics card at 665mhz or higher and the memory clock at 1043, The drivers become unstable. Would I need to increase the voltage to the graphics card it only runs at 40C, so its not going to fry anytime soon?
When I'm not OCing it, it runs at 30C
Also at the moment the CPU is running at 32C with no OC and the case temp is roughly 29C.
Do you think 3.8 GHZ would be safe? The settings I was going to use are:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: [AUTO]
CPU Clock Ratio ..........................: 9
Fine CPU Clock Ratio.....................: .5
CPU Frequency ...........................: 3.80GHZ (9.5 X 400 FSB)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 400Mhz
PCI Express Frequency (Mhz) .........:Set to 100
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: <<< 800
PCI Express Clock Drive.................: <<< 900
CPU Clock Skew (ps)....................: <<< Leave
MCH Clock Skew (ps)...................: <<< Leave
DRAM Performance Control
Performance Enhance...................: [STANDARD]
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: [333]
System Memory Multiplier ..............: 2.00
Memory Frequency (Mhz) ..............: 800MHz (2.00 X 400 FSB)
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time........................5
tRCD ......................................... 5
tRP'...........................................5
tRAS..........................................12-15
Advanced Timing Control
tRRD...........................................3-4
tWTR..........................................4-6
tWR............................................3-6
tRFC........................................... 52-62
tRTP...........................................3-6
Command Rate (CMD) ....................:2
Channel A
Static tRead Value.........................:7-10
tRD Phase0 Adjustment...................:<<< Leave for all below as well
tRD Phase1 Adjustment...................:Auto
tRD Phase2 Adjustment .................:Auto
tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)....................:Auto
Twr2wr(Different Rank)...................:Auto
Twr2rd(Different Rank)...................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control...............:Auto ps
Dimm2 Clock Skew Control...............:Auto ps
Channel B
Motherboard Voltage Control
Voltage Type.………... Manual
CPU
CPU Vcore….……….........................: 1.35
CPU Termination…..... 1.200V*.......: <<< Leave
CPU PLL…………………....1.500V*.......: <<< Leave
CPU Referen.…………....0.755V*.......: <<< Leave
CPU Reference2………,,0.800V*.......:<<< Leave
MCH/ICH
MCH Core…………….....1.100V...........: << 1.3 (Needed for 2x2GB Ram)
MCH Reference….…….0.800V...........; <<< Leave
MCH/DRAM Ref.…......0.900V...........: <<< Leave
ICH I/O……………….....1.550V............: <<< Leave
ICH Core…………...……1.100V............: <<< Leave
DRAM
DRAM Voltage ……....1.800V............: 1.9V
DRAM Termination .…0.900V............: <<< Leave
Channel A Reference 0.900V............: <<< Leave
Channel B Reference 0.900V............: <<< Leave
Advanced Settings
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: [Disabled]
x C4/C4E State Support..................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Disabled]
Virtualization Technology................: [Disabled]
, I currentlu have:
GA-EP45-DS3R
Clock Chip Control
Channel A
Channel B
CPU
MCH/ICH
DRAM
Advanced Settings
