Overclocking gives me lower performance??
7 Dec 2002
UK
I'm running an old system with a 3570k, RX580, Asus P8Z77V, Corsair 750w PSU and Corsair Vengeace 1600MHz RAM.
I ended up resetting the BIOS trying to fix an issue that turned out to be a dead HDD and am trying to get it back up to it's previous overclock of 4.4GHz (it was stable at 4.5+ but it was getting toasty, i've since changed the cooling though so would like to go higher if poss)
When I overclock performance increases as expected, however to get past 4.2GHz i need to up the voltage a little as at stock it seems to want to undervolt & run at 1.088v.
I'm noticing performance loss in benchmarks as soon as I touch the voltage though which I find odd, anyone want to shed some light on what might be happening here?
Some results -
  • Default Settings (3670MHz / Load temp 53c / RAM Speed DDR1333)
    • Intel XTU Score 702
    • Passmark 3668.6
    • CPU Mark 5014.9
    • Memory Mark 2382.6
  • If I set XMP I get (4181MHz / Load Temp 64c / Ram Speed DDR1600ish)
    • Intel XTU Score 570
    • Passmark 3876.6
    • CPU Mark 5555.0
    • Memory Mark 2374.1
  • If i leave all settings stock but just change the multiplier (4100MHz/Load Temp 61c/DDR1333)
    • Intel XTU Score 735
    • Passmark 3999.5
    • CPU Mark 5733.6
    • Memory Mark 2509.4
The XMP score was disappointing so i'm trying to figure out what's going on, so keeping all settings the same as above I manually set the Voltage Offset to +0.110v which gives me a load voltage of 1.296v which is about where I had it in the past & waht i Need to get to the 4.4-4.5GHz + area & scores drop, even setting it to +0.005v kills the scores & it seems to actually drop the voltage from the Auto setting.
  • At 1.296v (4100MHz/Load Temp62c/DDR1333)
    • Intel XTU Score 549
    • Passmark 3895.7
    • CPU Mark 5521.1
    • Memory Mark 2355.4
Any ideas as to what is going on?
Hmmm, what's the voltage settings in play there? I only see the 1.296v for your voltage modified benchmark at the bottom.
I don't have experience with the Bios from Asus from that generation or I'd be able to suggest more to look over. But I know that I never enabled XMP on the Z77 rig I have, just manually selected the frequency and that was it. XMP threw a tiny tantrum every time instead when I did try to get it going.
A quick benchmark reference for comparison:
3570 (non-k), 4Ghz (x40 multiplier), running at 1.07v at load (0.78v at idle), max 58C package (due to cooling decision), 16GB DDR3 1600Mhz Corsair Vengeance (via 4 x 4GB Sticks), HD7750, Gigabyte D3H Z77
Intel XTU Score : 782
And this was done over a Remote Desktop connection to the Z77 rig. How hard did you run your CPU and PSU previously? Could it have degraded them from prolonged extended use?
For reference, I tried to move a Corsair HX650W Bronze PSU over to this Z77 rig, to replace the Corsair HX620W 80+ inside it. But found that the hard life it had in the main rig it was powering, has left it with a louder fan and voltages that are in a wider margin of error than the existing HX620W because it was used less. Swapped them back around afterwards. Wondering if that might have happened here also? The Z77 + 3570 chips were from 2012 after all, so at least 7 years old.
It was at 4.5GHz for a year or two but then dropped back to 4.4 as I started to get a few issues, it's been at 4.4GHz for at least 6 years.
It was sat under an Arctic Freezer 13 Pro but I just swapped it to a 280mm Arctic Liquid Freezer 2 AIO as the bearings were going in the fan & the new cooler looks to be AM4 compatible which fits my plans for next summer.
There are no stability issues, if it wasn't for the benchmarks I might even not know of any problem, I can get it back up to 4.5GHz and it not fail Prime 95 but it's not playing ball in benchmarks.
