overclocking gt7800
26 Dec 2005
Manchester
what program do u use for overclocking ? :P
Isn't there a program that tells u what speed ** gfx will run best at ?
and how do i overclock my operton 144 :P
You can use a few different programs for overclocking but two I have used are Coolbits(Nvidias own) or Rivatuner, both are able to tell you optimal settings from what I recall and you can then manually clock further from that point if you should want to. Keep an eye on temperatures and if there are any artifacts appearing.
To overclock your Opteron you will have to go into your bios and adjust the settings from there, take a look in the overclocking section of this forum and have a read up on the basics though.
