Hey, so currently my GTX 460 is stable at 825mhz core (linked shader) and 2100 mhz memory - using stock voltage. (MSI afterburner)
I'm trying to push it further up to 900mhz core, it's not stable on stock voltage so I tried 1.087v, the max it will go and yet display driver still crashes with core at 900?
What gives? if it can run 825mhz on stock but not an extra 75mhz on max voltage in Afterburner?
GPU-Z reads the voltage increase, but i'm wondering if MSI afterburner actually changed the voltage value or not, and just shows a bogus 'altered' value? Is there anyway to confirm what it really is?
Thanks for reading, any help appreciated.
It's fine at 1.087 running 900/2050 but not 900/2100. The latter gets through kombustor fine but Heaven benchmark crashes it.
