Overclocking Guide/Explanations
1 Apr 2013
Dundee, Scotland
I know your time is limited 8PAck as your so busy but i was wondering if you could explain Overclocking especially the DVID/OFFSET method when i was overclocking fixed voltage was rather easy to learn but when i wanted to move onto DVID/OFFSET as suggested by wazza (thanks for all your help dude) i found the lack of guides/understandable explanations really disturbing.
im also confused by offset/Dvid/llc settings,as I can set llc low through to extreme and adjust dvid offsets(mine seems to need - offsets whatever llc settings I use)and there are very few guides on this matter that are clear,so much so I have for the time being,reverted to fixed voltages as I know where I am with these
it's easy,if you set cpu back to stock clocks/voltages you will see the stock voltage of your cpu in the bios info page
usually its around 1.15v,this is set by intel and it varies from chip to chip as some need more/less voltage for the required clock speed
offset adds the small amount you set for example + to add +0.010v will add 0.0100v to the stock 1.15v only at cpu load making it 1.16v,
negative offset will take off the amount set in dvid/offset from the stock cpu vid so -0.010v will be 0.0100v off the stock cpu vid = 1.14v
you then have to take into account what level loadline calibration you choose as each level will also add an amount of cpu voltage ontop of the stock cpu vid and the dvid/offset amount
this is where it gets confusing as its hard to judge how much each llc level adds,so its best to start with a medium to high llc and small amounts of offset/dvid until your relatively stable
stress the cpu each time while looking in cpu-z to see what your load voltage is,if its too high use one/two clicks less dvid/offset or one level less llc
if its too low and crashes add one/two clicks more dvid/offset or one level higher llc
keep tweaking until your happy with temps/voltages and stable
you can use whatever level of llc and offset amount you wish aslong as you balance things out,so high llc=low offset amount or low llc and high offset amount
hope that made sense,it sounds complicated but once you get used to it it becomes simple,ive had mine clocked upto 5.3ghz using offset and all powersaving turned on in benchmarks
100% stable at 4.8ghz
mmm,i totally get what your saying,my fixed voltage runs at 1.27v ,all day for4.3ghz,however if I set offset/dvid to 0.000v even on low llc my load voltage is 1.308/322,so now I have to use a -ve offset to get to 1.27v
what board are you using? it does seem rather odd that its using so much?
on mine a z77x up4 th I can set medium llc and +0.010v = 1.212v
are you using the latest bios?
its fine to use a negative offset,you just adjust either way to reach your needed 1.27v
if you clocked higher 4.5ghz+ you'd have to switch to a + offset as you would need more cpu voltage to be stable
But to run 4.5ghz I need about 1.35vfixed,if I set to low llc or higher the voltage goes up quite high and I still need a -ve offset,i must say,all the time my temps never go above 80c at 4.5ghz,but any higher and there in the 90 s,but im only running with a hyper 212+ cooler !!
im just saying,you don't have to clock that high,just clock to what you can with the cooler you have
it could be a bios bug idk but aslong as you undervolt it to whats needed itll be ok
for me it doesn't overvolt things so much,that could be down to a low vid cpu or more mature bios idk
I'm currently playing around with my CPU overclock and reading this has helped me understand a little bit more but there are a few things I would like to ask if that's okay (don't mean to hijack)
What's the safe voltage on a i5 2500k under water?
I'm currently at 4.5mhz @1.365v under load offset of +0.040v dvid 1.4011 under load (prime 95) temps 55c do these volts seem okay for this clock or? max (d5 pump, sr1 560 rad,7950 aquacomputer block,rasa CPU block,4xcougar 140 mm rad fans)
4.6 seems to need a substantial bump in voltage I haven't got it stable but close at 1.396v this seems like excessive volts for this clock would I be right or?
Does it seem that the 4.4-4.5 is the sweet spot or?
I only use this comp for gaming so should I just leave it where it is for 24/7 will I see any benefit in going higher or?
Sorry for all the questions.
I prefer to stay under 1.4v if I can,thats in cpu-z
does seem high for 4.5ghz but each chip is different
4.5ghz tends to be the swetspot yes for voltages unless you have a golden chip
Is it just luck of the draw if you have a Golden Chip?
Wouldnt mind swopping my 3770k out for a Golden chip.
@ 4.5ghz, my 3770k uses around 1.27v under load (temps around 60-70 degrees, antec kuhler 920)
Ive had it running on 4.6ghz but when I try higher clocks I run into probems. I asked 8-pack b4 about possibly hitting 5ghz or 4.8ghz, but I dont think my chip is capable.
Chris
Its just pure luck yes, my 3770k does 4.5 at around 1.208 loaded with prime at just under 70c some need more some need less
