had a little play around with the ati overdrive tool, the limits are pretty low so just maxed it out -
clock - 675mhz
memory - 1050mhz
passed the overdrive custom clock test, but occasionally came up with a problem and deciding to reset the settings (resolution etc) but kept it overclocked as above.
not entirely sure what it's going on about, have a accelero twin turbo and it's idling at 29c so no temp problems, do you think this might be a program error (try rivatuner instead?)
clock - 675mhz
memory - 1050mhz
