Ok my set-up is as follows:
Processor: E6300 (B2 revision) with Artic Cooling Freezer 7 Pro
Motherboard: Gigabyte GA-965P-DS4 (rev1.0 with F11 Bios)
Memory: Corsair PC2-6400 4x2GB (Just upgraded from 2x1GB Geil)
Other Stuff: HD4670 512Mb, 580W PSU. Running Vista 64
I have been relatively sucessful in my overclocking so far but seem to have hit a ceiling.
I started out by disabling CIE & EIST and locking the PCI Express frequency to 100mhz. I switched the voltages to manual but left everything at their 'normal' voltage (CPU 1.275 and RAM 1.8). I started creeping up the FSB adjusting the memory divider as I went to ensure the memory was running as close to its stock speed as possible (therefore testing the CPU ceiling, not the memory?).
Unfortunately I can't get the computer to post past a FSB of 385Mhz despite seeing other people with the same chip, cooling and mobo hitting up to 485Mhz. I have tried pushing the CPU voltage up to as far as 1.4125 but it makes no difference at all. I don't know what to try next?
The only answer I keep getting if that it must be my memory thats limiting me. Now correct me if I am wrong but I'm pretty certain I'm not even close to hitting my memory's max. My FSB is 385Mhz, with a 1:1 divider I'm running under the 400Mhz you get for PC2-6400 Memory. When running at a FSB of 300Mhz with a 2:3 divider my memory runs fine at a speed of 450Mhz. So I can't see how being unable to step from a 385 to a 390 FSB can have anything to do with my memory.
Am I completely missing the point with the memory side of things or am I right in thinking its not the memory that is limiting me? and does anyone know what I can try next?
thanks Ade74
although that may have something to do with upgrading from 2GB to 8GB of RAM.
