Ive got an Intel Core 2 DUO E4400 and I've overclocked it to 3gHz. I seem to be having a slight heat problem because under full-load, its touching 60˚C. I have the following rig:
CPU: Intel Core 2 DUO E4400
CPU Heatsink: Arctic Cooling Freezer 7 Pro CPU Cooler
Memory: Team Elite 2GB (2 x 1GB) DDR2 PC2-6400C5 800MHz
I'm wondering if its a CPU cooler problem, and if so what CPU cooler would you recommend? I'm a bit stubbed to be honest because using the stock cooler its 63-65˚C.
(This is not in a case, its on a table, so its not a ventilation problem
Thanks in advance,
- Saul.
)Thanks in advance,
- Saul.
