- 9 Oct 2011
- UK
Hey guys, well I picked up a 5930K, a MSI X99A Krait Edition motherboard and 16GB of Corsair Dominator 3200Mhz RAM the other day and I need some help overclocking it as the OC Genie 2 is crap, with it set to Gear 2 as it's known it only does 4Ghz, My 2600K on a Asus motherboard did 4.4Ghz with it's auto overclocking system.
I would really really like to get at least the same from this chip if I can, according to a article I've seen pretty much all 5930K's should be able to do 4.3Ghz to 4.5Ghz.
I've tried doing it myself but not getting anywhere, I put in 44 multiplier and put the voltage to 1.3 but after 5-15 minutes of Prime 95 it blue screened with some sort of Watchdog error, it was running around 30c idle but it was getting up to 86c at some points in the test, then it would go down to about 67c and then back up, this is with a Corsair H100i GTX cooling it, with the same cooler on the 2600K at 4.4Ghz I was getting around 30c idle and 50-55c at load, so what the heck, 30c more for this and it's not even stable? eesh.
Please can someone help.
