Havn't done much overclocking in the past, just clocked my Intel E6600 from 2.4ghz to 3.0ghz (333 x 9) I have an Asus Commando MOBO.
My question is about memory, I have 4gigs of DDRII 800 which, now that i've o/c'd the cpu has gone to 400mhz.
This is my CPU-Z readout, what's my next step with the ram?
Number of processors 1
Number of cores 2 per processor
Number of threads 2 (max 2) per processor
Name Intel Core 2 Duo E6600
Code Name Conroe
Specification Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
Package Socket 775 LGA
Family/Model/Stepping 6.F.6
Extended Family/Model 6.F
Core Stepping B2
Technology 65 nm
Core Speed 3003.1 MHz
Multiplier x Bus speed 9.0 x 333.7 MHz
Rated Bus speed 1334.7 MHz
Stock frequency 2400 MHz
Instruction sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4096 KBytes, 16-way set associative, 64-byte line size
Chipset & Memory
Northbridge Intel P965/G965 rev. C2
Southbridge Intel 82801HB/HR (ICH8/R) rev. 02
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Memory Frequency 333.7 MHz (1:1)
CAS# Latency (tCL) 4.0 clocks
RAS# to CAS# (tRDC) 4 clocks
RAS# Precharge (tRP) 4 clocks
Cycle Time (tRAS) 12 clocks
Command Rate 2T
System
System Manufacturer System manufacturer
System Name System Product Name
System S/N System Serial Number
Mainboard Vendor ASUSTeK Computer INC.
Mainboard Model Commando
BIOS Vendor American Megatrends Inc.
BIOS Version 0803
BIOS Date 01/30/2007
Memory SPD
Module 1 DDR2, PC2-6400 (400 MHz), 1024 MBytes, Nanya Technology
Module 2 DDR2, PC2-6400 (400 MHz), 1024 MBytes, Nanya Technology
Module 3 DDR2, PC2-6400 (400 MHz), 1024 MBytes, Nanya Technology
Module 4 DDR2, PC2-6400 (400 MHz), 1024 MBytes, Nanya Technology
Software
Windows Version Microsoft Windows Vista (6.0) Home Premium Edition (Build 6000)
DirectX Version 10.0
Thanks!
Code Name Conroe
Core Stepping B2
Technology 65 nm
Chipset & Memory
Memory Type DDR2
Command Rate 2T
System
BIOS Version 0803
Memory SPD
Software
Thanks!
