Just started overclocking for the first time an need some advice.
Firstly rig =
Q6600 + Arctic Freezer
Abit IP35
4x1gb Geil PC2-6400C4 800MHz
I have slowly been upping the fsb, which is now 333 with a multi of 9, am I right in thinking this is now 3gig? Just a bit confused by what cpuz shows. Mainl the core speed? Should this not be 3gig? Just noticed cpuz has my multi as 6, in bios it's 9?
Prime has been stable until now where 1 core gets an error after 15 or so minutes, the others were fine for about the 2 hours it was going. Do i now need to up the vcore slightly?
Finally my ram is set to default in bios so i assume i need to manually set the timings.
What should the following be set too:
Voltage is currently defualt should I change this?
Dram frequency currently 499 should this be 800?
FSB
ram currently 2:3
Cas (CL) currently 5 think this should be 4
Ras to cas delay (trcd) currently 5 think this should be 4
Ras precharge (trp) currrently 5 think this should be 4
Cycle time (tras) currently 18, think this should be 12
Command Rate 2T should be 1T ?
CHeers for any help guys below are screenies of CPUZ, CPU an RAM
Firstly rig =
Abit IP35
FSB
ram currently 2:3Cas (CL) currently 5 think this should be 4
