Ok guys and girls a nice easy one for you.
Iv overclocked my e2160 to 3Ghz and my voltage on auto.
Ram was running at 890ish Mhz
Temp was 34c ide 54c well playing a game.
I want it runnin at 3.2Ghz-3.4Ghz with the ram running at 1066Mhz
When i run it at 3.2Ghz and ram at 1064Mhz it dosnt work and the bios resets it
if i run the cpu at 3.2Ghz and ram at 860Mhz it gets to the windows startup screen and crashs.
If i run it at 1.8Ghz and ram at 1064Mhz it just resets the bios when the computer restarts
i think its to do with the voltage on the ram and cpu
can anyone help
my mobo is a 965P DS3
ram is Kingston HyperX 8500C5 1066MHz
can anyone help
and then i mite even push the cpu up even more
