Hey. I understand this CPU has a locked multiplier but I heard it can be overclocked some.
I read a site saying you clock the Blck at 105mhz and the multiplier to x38 I done this and it caused a lot of load lag on games and sound stuttering. I read that no voltage changing was required for this specific overclock so I dont know why it caused problems.
I then read that on the overclockers site:
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.35-1.38v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Can anyone recommend a way to overclock this CPU?
Thanks.
Thanks.
