Overclocking i5 2500K - CPU cooling options?
Noctua NH-C14 http://www.overclockers.co.uk/showproduct.php?prodid=HS-014-NC&groupid=701&catid=57&subcat=1395
Gets cracking reviews and can be used as low as 105mm if you don't use the top fan. Seems to be the D14/Silver arrow for HTPC's. Not sure on the thickness of the fans but i imagine using the top would would bring it to 137mm - 143mm, but it seems to perform great with just the bottom fan going by the reviews.
Pricey though.
Reviews http://www.overclockersclub.com/reviews/noctua_nhc14_review/
http://www.guru3d.com/article/noctua-nhc14-cpu-cooler-review/
http://www.techpowerup.com/reviews/Noctua/NH-C14/
Many thanks - this looks the business.
According to the reviews etc. it is 130mm with both fans on so it might be possible to fit it like that into an HTPC case - although there is the issue of getting air into the top of the fans if there isn't a grille directly above.
Knocks spots of the Gelid but haven't found a comparison with the AXP-140 RT yet.
Top of my (ever more expensive) list at the moment.:cool:
