Overclocking i7 970
Permabanned
26 Oct 2004
Isle of Wight
I'm currently overclocking a 970 for a friend and just wanted to get some tips and pointers.
It's currently prime stable at:
BCLK:160, Multi: 24 (25 Turbo) - 4GHz, 1.287v BIOS (1.264 CPU-Z), Ram: 2:10 (1600Mhz), VTT=1.3v
Temps are around 67°c, although oddly, core#2 is sat at 61c.
Do these look fine? What is the max, safe voltage for 24/7 usage and is there anything else I need to look at on my quest for higher speeds?
Yup that is all fine. Gulftown CPUs are known for poor temp sensors.
I prefer to run mine with a Bclk of 200, 4.4Ghz @ 1.3125V and VTT the same.
Keep the temps less than 80 degrees and cpu voltage less than 1.375 for 24/7 use.
Matt
