- 17 Apr 2015
Hey all, not sure what the issue is exactly so put this in general, i suspect it's a power supply issue but here goes.
been playing on my Rv520 laptop recently,
It runs 8gb ram, i5-2410m duel core and an nvidia gt520m graphics card,
When playing an intensive game like H1Z1, I'm getting frame drop and i've figured out why...
I always noticed the screen would flicker between dim and light, and I worked out this is the battery, I think the game is too intensive and is using up all of the available power, so much so that it does not have enough to constantly charge the battery, therefore it flicks between high performance and power saving mode (i've also tried it on balanced and i get the same outcome.
I realised this when I overclocked my graphics card using Nvidia inspector, I overclocked it from 740mhz to 800mhz, which increased my frames on medium settings to 40 consistent from 25-30, But It was not until my laptop flagged up saying 10% left i realised it was actually too powerful (i think thats the issue anyway)
I then put the settings back to stock, applying the defaults, which did not cure the now constant flicking from battery to mains, I then done a system restore to an update i made 3 days ago, but this has still not fixed the issue, It's flicking between battery and mains just as much now as it was when It was overclocked!!!
It's fine in any task apart from intense games, Heat is not an issue, Without my cooling mat i'm consistent at 55c with overclocking, with the cooling mat i'm sat at 45-49c consistently.
Is it just the power to the laptop that is not enough? the stock charger is 19v
Before overclocking, I could play for a few hours and only lose 2% battery from it switching to battery power for a second or 2 periodically,
Since overclocking (and then returning back to stocks) I played for 30 minutes and was down to 67%!!!
any advice? This laptop was bought in germany and has a 2 pin to 3 pin plug adapter on the end, could this be bottlenecking the power supply? or do I need a more powerful charger?
any advice is welcome,
Lee
Lee
