I recently got the
MSI Radeon R9 280X Gaming Edition OC
on 25 december
And wanted to overclock the card a bit but on GPU i have little experience
The card comes on 1020Mhz clock
So got MSI afterburner and i cant unlock voltage control no matter what
I also got Msi kombustor to stress the card for stability
So i started the fun
Got to 1170Mhz on the gpu with 18% power target but the card was overheating at 80 degrees with 100% fan there were small artefacts from time to time
At this point i opened the window and stopt
Running perfect at 1140Mhz with 10% power target 76 degrees window open
On the memory i was able to go to 1720 Mhz with 5% power target 1740 Mhz will work only with 10% power target
So got to combine the outcome 1140 Mhz on gpu and 1720 Mhz memory 16% power target at 76 degrees window open
What is the maximum i should run the card 24/7 ?
1100 Mhz GPU and 1650 Mhz Ram how does it sound?
on 25 december
