) but more likely the Northbridge Strap, Have you manually set the FSB-Strap or are you just changing the DDR2-Frequency option? . . . if the FSB-Strap is on Auto then the problem may be the board setting the strap too aggressively, if thats the case give it a cup of vNB and see if that helps!
