Hi chaps,
I've had a fair degree of success with overclocking my E6600.
Equipment is below:
E6600 Currently at 3.1Ghz on water (344x9)
4GB Corsair DDR2 XMS2 DHX PC2-6400C4DHX TwinX (2x2GB)
Asus P5Q Pro
Enermax 625W Modular PSU
Powercolor 4870X2
Vista X64 Ultimate
Things started to get a bit flaky over 3.4Ghz, and very ropey at 3.6Ghz which was/is my target.
Basically what happened is that I started to get BSOD's around 3.45Ghz, and decided to be a bit gung ho and upped the Vcore and went for a direct 3.6Ghz, which ended up in BSOD's. I wouldn't usually be so ham fisted, but the chip was a hand me down from a friend (for free) and thus i wasnt too bothered about frying it.
So I then backed down the OC to 3.2Ghz and noticed the BSOD's kept happening, so I changed my voltages (which I stupidly hadn't written down at this stage). However, when I removed the clock completely, I was still getting BSOD's.
I basically attributed the BSOD's to a stuffed Windows install and thus reinstalled windows. Sure enough I was able to clock again without the BSOD's.
However, without my old voltage settings i'm effectively having to start again with the OC.
As I mentioned before, its currently at 3.1Ghz due to the time overclocking takes, and the desire to play the backlog of games I have
but I've had it running reasonably stable up to 3.4Ghz. However, i've noticed that with the memory divider set to auto, I either get very low memory speeds (which the BIOS says will cause instability) or very high speeds (have seen 933Mhz at one point). I understand that this is due to the memory not running 1:1 which it would at 3.6Ghz, but how dodgy is it to run at speeds away from the spec'd operation speed (I.e. 800Mhz)?
Also, with regards to the memory speeds, to what extent is safe in terms of stability? and is it better to have the RAM underclocked or overclocked, whilst trying to achieve the target/1:1 figure?
Thanks for your help in advance guys, i'll try to post my BIOS settings when I get in.
Equipment is below:
Asus P5Q Pro
Powercolor 4870X2
Vista X64 Ultimate
