Overclocking memory same time as CPU?
30 Nov 2010
UK
Hi,
Is it best to overclock the CPU first or after the memory or has it got to be done the same time? I have been trying to overclock my CPU and set my ram timings/voltage at the same time, but how do I know what is causing BSOD?
Using:
Asus V Gene Z77
2500k
HyperX gensis grey 4GBx2 1600mhz
I wouldn't do them both at once, as you won't be able to isolate the cause of crashes.
Personally I'd get a reasonable OC out of your CPU before touching the RAM.
