- 1 Dec 2008
Just wondering if first of all, is it actually worth doing, and if so....How?
Oh I take it that is 4 x 2gb of ram? If so you might have trouble getting it higher than 800mhz as it puts more strain on the NB.
You can try lowering the multiplayer on the cpu, and raising the FSB. You might need more voltage for the ram, but be careful to not put too much through the ram. Then test with Prime95 / Memtest.
Post specs! if youv overclocked your processor then your memory could be a bottleneck, but if youv overclocked your processor, youv most likely overclocked your ram lolwell unless youv changed multipliers etc.
