Overclocking Memory
22 Aug 2011
Cardiff Central
Using PC in sig.
Is it worth overclocking RAM?
Is it possible on my board with my particular brand?
If so how does the process work?
(Also I'm pretty sure that memory is separate when it comes to overclocking on LGA1155 boards, but do I need to take anything into account considering I am overclocking)
not worth it. very few applications take advantage of memory faster then 1600mhz and in games theres no difference.
Will you be able to overclock? Yes, I don't know what the oc limit on that RAM will be though. Will you see any real world benefit? Probably not . Will your benchmark scores go up? Yes
