I have just been told to change some settings in bios to get my over clocking working but it was not so clear.
so thinks where clear others not
It said change
DRAM Frequency to 1368mhz but it would only go to 1395mhz is it ok ?
DRAM Voltage to 1.65 so i changed the DRAM Core Voltage is that the same thing ?
Also go into Dram timings an change it to 9-9-9-24 on cas latency setting so i changed it to 9 Dram Clock not sure if thats right.
any answers will help im sure
Thanks
It said change
Thanks
