Overclocking monitor problems ...
4 Mar 2008
Hi,
I have a 60Hz monitor that I can run at 90Hz using the NVIDIA control panel custom resolution setting. My main video card though is an AMD R290 so I have to use CRU to set a custom refresh rate when using the AMD. The problem is that the only monitor refresh rate that even shows up is 80Hz. Any others I create simply dont show up in the monitor preferences. The monitors cleary capable of it as when using a GTX760, I can set lots of different refresh rates in the NVIDIA software.
So, any ideas how to get CRU or something else to give me a 90Hz refresh rate again?
