Overclocking MSI Cyclone 460GTX
2 Aug 2011
Newbury
Not sure if this should have been on Overclocking or Graphics card section.
Doing a few tests on my GPU and comparing the benchmarks. Not sure if it's as interesting to some as it is to me. Using MSI Kombustor software to benchmark at the res I play 1600x1040 with 4X AA. Using the stock clock of 727MHZ I averaged around 159FPS but with the overclock of 845MHZ I get around 190FPS. Is that jump normal?
I tried hitting 885MHZ and after 10 seconds the benchmark freezes and it says my driver display error-ed. My current Voltage is 1.012, should I increase it for the 885MHZ OC or would it not change much and the card is limited.
Temps during benchmark hit a max of 65C which to me, is good I think
Any idea folks!?
