Overclocking my 3700+
25 Nov 2004
Hertfordshire
Thought I'd give it a go - just to see how I get on, heres what I have so far...but I dont know whether I'm going about it the right way...lol so any advice appreciated.
Spec:
CPU: Athlon64 3700+ San Deigo
Mobo: Asus A8N-E (nForce4 Ultra)
RAM: OcUK Value 2GB
GPU: Radeon X850XT
Current settings:
Running the RAM at 2.5-3-3-8
I've put the HTT down to 4x, dropped the memory to 333 (is that the right thing to do???) and have been increasing the FSB and currently at 250, giving me 2750Mhz...currently at 1.45v
About to run some benchmarks, but am I doing the right things?! :D
If it's stable that great, mine would only go to 2500 mhz! But yes the settings you have set are correct.
Try a bit more voltage..
i put 1.6 volts through mine to get 2.8 stable :)
EDIT : Thats with a scythe ninja cooling it though
aye sounds about right
Same divider for me and running 250 x 11 for 2.75ghz - mine is at stock volts for that. Ram on 2-3-2-5 with the 333mhz divider.
Ok, thanks for the replies, I'll give the voltage a go.
Cooling is a Big Typhoon btw, forgot to mention that. Although - my room is pretty warm so temps are a bit high. :(
Well idle at about 39 @ stock due to the weather...
I tried more voltage, but for some reason, my system kept locking at boot over 1.475v. It'd stop just before the windows loading screen.
I tried playing about with HTT 3x, but that didnt help. Managed to get memory to 2.5-3-3-5...but I dont think that'd make any difference.
Back at stock now, any ideas?
trojan698 said:
What board are you using?
Asus A8N-E, i said in the OP :)
Been playing around a bit more, and it boots up at 250x11 HTT @ 4x without a problem at 1.475v. I will prime test at that voltage and see how it goes, increasing if necessary. What's considered a reasonable length of time to run the test for without errors to assume a stable clock?
Also, I tried dropping the HTT to 3x just playing about to see if I could go above 250, but then it kept stopped before the windows logo again.
To say that system is stable enough i would say you need to be able to run for 12h with no errors. If you want make sure your system is rock solid then for 24h with no errors ;).
Hope it helps.
Cheers
Everyone has their own idea of what stability is IMO,
My CPU @ 2.8 Doesnt Pass Prime 95...
But it can play counter strike source and battlefield 2 for hours and hours non stop without failure / crashing
