Good news, I managed to return my 800mhz Ram so It looks like the £70 notes is now buying me a nice new Trackir system. Yay
Cairnsey said:
How did you mange fsb of 266 without the PCI lock on this board? thought anything aover 33mhx incrase made this board unstable because there's no PCI lock
It could be that I have the 4core VSTA board?. I read that some people couldn't clock the Dual VSTA very well without updating the Bios first.
Here's what I changed in the bios for my current OC which is stable at 2431mhz with my Ram running at 168mhz stock cooling and voltage.
Overclock Mode - CPU,PCIE Async.
CPUFr. - 270
PCIE Fr. - 101 (only 1mhz diff but apparently helps stablize overclock)
Spread Spectrum - Disabled
Boot Failure - Disabled
Max CPUID Val. - Disabled
Intel Virtuali. - Disabled
CPU Thermal Thr. - Disabled
No-Execute Memory. - Disabled
Intel Speedstep - Disabled
Chipset:
Dram Freque. - 166
Flexib.- Disabled
AGP Voltage - HIGH (Even if using PCI-e apparently helps with overclock)
