Overclocking my MSI 7900GTO
J_K
J_K
29 Nov 2005
Notts, UK
Just got my MSI 7900GTO installed and running and im very happy so far. I've installed coolbits and ran the "detect optimal frequency test" and it came back with around 700MHZ core and 1.43GHz for the memory. For some reason it wouldnt save the core at that speed so set it to 686MHZ which it tests ok at and lets me save.
Seems stable so far, just wondered if I should be expecting to clock it higher or should I stick with those levels??
Ran 3dMark06 and got around 4500 which is probably down to my processor holding it back. I'm on a P4 3.0GHZ with 2GB RAM.
Also just to note the card is running fine in my Dell precsion 370 even though the power supply is only 350W I believe. Idle temps are around 38-40degrees, I'll have to log full throttle temps and post. It's so quiet aswll, v happy :D
