overclocking my new build
18 Dec 2009
Guys ,
recently built my new rig and im trying to overclock it using Smart 6 but it dont seem to work , any other programs available to use as i am not confident enough going into the bios and doing it.
I5 2500 @3.3ghz
Gigabyte Z68X-UD3H-B3 Motherboard
16gb Kingston HyperX Genesis Grey 8GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit RAM
x2 Radeon 7970
850W XFX PSU
Corsair H100 Cooler
Regards.
cant overclock the 2500 needs to be the K version
how long have you had it and is it from OCUK cos you should be able to return under DSR
Found a utility called touch bios , set it to 4.5 and it's all good just stress testing it now on maximum , fingers crossed..... Thanks for your help
i seem to be stable at 4.2 (42) 16 multiplier and a v core of 0.996 , the burn test on maximum was successful , my temps are 21 idle and 65 full load , can i push it further?
