Hi ^_^
I have an opteron 146, CACJE Stepping, I dont know the batch numbers :S
My Entire spec
AMD Oppy 146 (using the Zalman 9500LED)
G.Skill 2GB DDR HZ PC4000
Gigabyte K8NXP-SLI Motherboard.
7800GT 256meg Leadtek
250gb Western Digital
Pioneer DVD-RW
Tagan 530w PSU (Silent Modular, Dual rail)
Okay, Ive established that I can run stable at 2.5Ghz @ DDR500. with a 2/2 divider. Now when I go to 2.75Ghz @ DDR500. My games run fine, windows boots, I can play BF2, CS Source for hours on end and yet, when I run prime 95, I either crash within 10 seconds, or 6 minutes. Rounding Error. Ran Memtest for 6 hours with no errors.
Ive set my CPU Voltage to 1.55V. RAM at 2.8V Timings 3-4-4-8. Using the divider as 2/1.83. Chipset upped by 0.2Volts.
Is there anyway to make my computer more stable? I would really like to hit the 2.9~3Ghz barrier.
Is it something im doing wrong :S. Thanks for the advice in advance!
My Entire spec
Pioneer DVD-RW
Then kept everything the same
