- 14 Jan 2010
- Dover, Kent
I bought the Gold Rush 4770k kit off OCUK a few years back
Had a 4770k clocked to 4.4ghz, Asus Z87 Pro, Dark Rock 2 cooler and 16GB Team Group Vulcan Gold 2133Mhz memory (4 sticks of 4GB)
Thing was it was just never stable. When I reached out for help ocuk told me to try a few things but it was never stable. I was told to load optimised defaults, then I got so drawn in with work and everything else I never touched it again and the 24 month help period came and went. My pc was still fairly quick and had stopped bsodding regularly so I left it.
Anyway I was thinking recently I needed a bit more speed and started looking at new parts recently but felt that actually my current PC should be capable of much more.
Currently since setting to default my memory has been running at 1333mhz, and my turbo is at 3.9ghz for the last couple of years.
I'm a complete OCing luddite, hence buying the pre-clocked pack. I tried using AI Suite 3 yesterday and did an auto tune thing and it set my turbo to around 4.3Ghz and had memory back to 2133mhz. Thing is, it just kept crashing. Even though under apparently what this was once shipped with. I did some Prime95 tests and it was sending my temps into the 80s almost instantly too. (Case is a Define C btw, 2 AF140s in the front, single stock Define 120mm fan exhaust). My temps now as I'm sitting here just with Discord, Chrome and Steam open (No games) are bouncing around the mid 30s. My room temp is currently around 24c. It's like this sort of temp or higher all year round.
Anyone any good ideas? Shouldn't my memory at least be running 2133mhz? Maybe it would help if I had a bit more cooling (Saying that I had trouble back when I used a Define R4)? I'm just trying to go for near silent but fast usage. Quite hard to get that balance going.
