overclocking myq6600 b3
21 Jul 2007
Newcastle upon tyne
Overclocking myq6600 b3 UPDATED I AM HAPPY!
goin to overclock my q6600 b3 and i am not sure what fsb speed , i am wanting to get it up to 3.0ghz but will the fsb speed at 1066 be ok?
spec are mobo: nvidia 680i sli
cpu q6600 b3ram: ocz 4gb vista upgrade PC2-5400 @ 667mhz ddr2
also any ideas on memory timings please and voltages for cpu and ram
cheers
edit:
just been reading over some overclocking thing on ocuk and tom hardware, a pdf from nvidia about overclocking and i have done a little overclocking
here a pic, i am goin to let it run like that for a day or 2 then run prime95 in the meantime as i am new to overclocking and this is my 1st time overclocking
Well the FSB will have to be 1334mhz.
You might need to go as high as 1.35v in windows (as read by CPU-Z) to get 3ghz stable on a B3.
cheers
edit:
remember the overclock will be limited by all that ram, mine is only stable at 3.1 with 4gb ddr3
yeah I know that but , I was just wondering i've got it at 3.2 now and i'm happy with that. Don't wanna push the temps to high there running at 55 ish under load , which is fine by me
