Hi, didnt have much success overclocking my CPU. some strange problems, so im deciding to OC my GPU instead.
Its an Asus 9800GT 1024mb card. Its got the huge stock fan that came with it. Its idle temp is 42c.
GPU-Z shows its currently set to: 600 clock, 900 mem, 1500 shader.
I believe it should be easy to get it to 674/956/1662.
i just dont know the best software to use.
thanks
Joe
thanks
Joe
