I've got an i7-930, which I've had from new (when they were out). My cooler is the Corsair Hydro H50 (fitted since new).
I had overclocked it in the past, but after installing some dodgy memory many years ago, I left it at stock after I removed the memory (as I needed stability more than speed). Now I'd like a bit more speed, so I've been running tests again, following the handy guides I used before.
To start with I set it to 21 * 160 BCLK = 3.36 GHz, with a voltage of 1.1
According to the guide, running Prime95 should give temps around 60 to 65c. I was at 80c after 20 minutes (using RealTemp 3.7).
Regardless, I did some other test: 3.8GHz, 1.2125 V, getting temps up to 96. I got a BSOD before I cancelled the test.
I'm now at 3.57 GHz, 1.15625 V (I haven't tweaked it, I just tried that) and got temps of up to 90 after 1 hour of Prime95.
Is the problem most likely to be:
a) a malfunctioning cooler
b) just the way it goes with an old CPU
c) a poor connection between the CPU and cooler (due to age)
d) something else
Other info:
Windows 10
Motherboard = Asus p6x58d-e
Case = CM 690 II Advanced
Fans = quite a few 120mm, all seem to be working
GC = RX 580
RAM = 18gb corsair DDR3
PSU = Super Flower Golden Green 650W '80 plus gold'
Thanks
d) something else
Other info:
Windows 10
GC = RX 580
Thanks
Which should I try first?
