Overclocking on a B650E Aorus Elite X AX ICE
13 Sep 2024
Manchester
Bit of advice please, I have B650E Aorus Elite X AX ICE, 9800x3d. Would like to Overclocking it a bit. Expo is on, but when I go into the PBO I don’t know which level to select. Any advice would be greatly appreciated.
When I did mine I just copied the settings from this YT video for PBO and CO
At 7 mins 25 seconds is the PBO details, you can go directly to this or use the time stamps in the description.
Advice pls. Cinebench r23 score is only 16963. CPU Temp is around 80, Power is around 110, clock speed 5400 when doing the test.
This is what I’ve changed in the bios.
Expo is set at 1
Precision Boost Overdrive - Advanced
PBO Limits - Motherboard
Precision Boost Overdrive Scalar - 1x
CPU Boost Clock Overdrive - Enabled Positive
Max CPU Boost Clock Override (+) - 200
Curve Optimizer - -20
Bios Version is F34f
Thank you for any help.
Expo is set at 1
Are you using hwinfo to monitor? Is it maintaining the clock speed throughout the whole benchmark? Your power draw/clock speeds does look normal so you should be getting over 20K points in R23... Try running Cinebench in safe mode to rule out background programs. Also update BIOS if it isn't on the latest.
I did a bios reset, before I changed anything in bios after rebooting I ran cinebench r23 which gave me a score of 23146. So not sure what the issue was but it sorted it out. So after playing with the bios settings this is what I’m sicking with.
Expo 1, oc - 30, + 200 so speed is 5.4, PBO set to MB limits, Thermal Throttle set to 85 and all fans adjusted. Cinebench r23 score is now 23958 with temperature of 82 under full load. So quite happy with that. But my bios is not the latest so unless something breaks I’ll just leave it alone for now. But thank you for the advice.
