Overclocking on Maximus V Gene
14 Nov 2012
Chesterfield
I've managed to find all the settings which allow me to specify overclock settings, but for the life of me, I cannot find where to set/change the cpu multiplier.
What would it be called? Where is it?
On another note, AI Suite has successfully overclocked my chip to 4.5ghz. Would there be any issues with manually clocking my RAM?
don't thinkso
how much cpu voltage at load? be carefull it doesn't apply too much
just up the ram multi/speed and set the dram v to suit,anywhere from 1.5v to 1.65v 1.55v tends to be the sweetspot
vccio/sa should be ok unless you have 16gb,then two/three clicks more over stock
seems a bit high,
try high llc
cpu voltage offset mode
+0.010v in offset
cpu current capability 120%
phase control extreme
heres what I use on an asus board they are all pretty similar,can use less llc and less offset later depends if you remain stable
http://forums.tweaktown.com/asus/47510-asus-z68-v-pro-4-5ghz-bios-screenshots.html
Thanks for that - it would seem that even with the defaults loaded in the BIOS, 1.328v is the default.
I've applied your recommendations and will run BF4 to see how it goes. I assume if I get a BSOD on 124 it'll be more offset.
You can try it,try 4.6ghz then 4.7ghz
4.5 works a treat - pushed for 4.6 on the same settings and got a BSOD - 3B ( I think)
This is how it looks under prime, testing with BF4 shortly:
Happy with that, was less trouble compared to my old AsRock board.
how much cpu v at load now? for 4.6ghz you can try with offset at +0.020v,maybe +0.025v +0.030v for 4.7ghz
haha yh its poor,i used to get that and temp at 100c+
it hasn't done it for a good while though but I remember it doing it
Started getting bug check code 124.
Should I increase the offset, currently set to +0.015 or increase QPI/VTT?
Running 8gb RAM in dual channel
